Zoals ik heb gelezen op het interweb (dus in hoeverre dat klopt, weet ik niet natuurlijk) dat er soms wel wat klachten zijn over de toetert van de R1200RT (de zgn. Fading Horn);
---- knip ----
http://bmwdean.com/r1200rt.htm
The Incredible Fading Horn
The 2005 and early 2006 R1200RT motorcycles came with loud, two-tone horns that were very effective. Midway during the production of the 2006 models, however, BMW replaced the two-tone horns with a single “beep” that is minimal and, to me, completely unacceptable. I have no idea why this was done, other than to save precious few dollars. The replacement horn is ineffective in warding off drivers drifting their cars into your lane. When I traded my 2005 in on a new 2007, I had the dealer swap the horns so my new bike still has the two-tone version. I recommend that owners of R1200RTs with single-tone horns replace their one horn with two-tone horns as soon as possible. Either secure original 2005 BMW horns or get aftermarket horns from an auto supply store.
Just in case the reason BMW replaced two horns with one was because additional electrical load caused problems with its sensitive electronics, I took the precaution of wiring the two horns directly to the battery and connecting them to the R1200RT's wiring harness's positive horn wire through a relay. I had done this with my 2005 R1200GS using an inexpensive auto relay (part no. 275-226) from Radio Shack. Having installed a relay, I have had zero problems with dual horns on my R1200RT.
---- knip ----
En
http://www.bmwlt.com/forums/archive/ind ... 29303.html
Kortom, e.e.a. is afhankelijk wat de toetert die je nog hebt liggen aan specificaties (lees: stroom-opname) opgeeft, staat waarschijnlijk wel op de behuizing, verpakking of documentatie.
Zo'n Stebel Nautilus toetert is een luchthoorn, en die trekt...15 ampère, vandaar de opmerking van de noodzaak van een relais.
Maar, luister anders eens op de navolgende link voor een impressie;
http://www.valkmotorparts.nl/producten.php
En anders een keer je toetert die je nog hebt liggen op 12 volt aansluiten nabij je fiets en vergelijken qua geluid (en volume!) of dit beter is dan je huidige toetert.
