GoPro HD Hero Firmware Update v02.05.11
Marruk8865
Ik weet niet of het oud nieuws is, maar voor de GoProHD gebruikers onder ons is er een firmware update beschikbaar.
Aangezien ik mijn camera al lange tijd niet gebruikt had kwam ik daar zojuist pas achter.
De nieuwe of gewijzigde functies:
One Button Mode
One Button Mode simplifies recording video and photos with your HD HERO. With One Button Mode, your camera will start recording video or photos automatically when you power the camera ‘ON’ and will only stop recording when you power the camera ‘OFF’. The shutter button is deactivated in One Button Mode. You can only turn the camera on and off, making it the perfect setting for loaning it to friends or newbies.
Upside Down Mode (UPd)
Now you can take videos and photos with the camera mounted upside down without having to rotate the files later. In UPd, all videos and photos will be saved to your SD card right-side up.
Live Feed Out
Display live feed SD or HD video and audio straight out of the camera to a TV, handheld viewer, or video transmitter. Allows viewing a live video signal during preview, recording, and playback of saved files.
Live Feed On-Screen Display
Display battery life, camera mode, and recording status icons on your live feed video signal with ‘On Screen Display’ turned on, or turn it off to transmit only the video without any status icons.
PAL 25/50 fps Support
If you live in a PAL region (most regions outside of North America) you can now record in the PAL broadcast standard of 25 / 50 fps in the following resolutions:
r1 WVGA 50fps
r2 1280×720 25fps
r3 1280×720 50fps
r4 1280×960 25fps
r5 1920×1080 25fps
Hier de update-instructies: http://gopro.com/wp-content/uploads/201 ... ctions.pdf
Hier de pagina om de update te downloaden: http://gopro.com/support/hd-hero-firmware-update (onderop na invullen naam en email)
En hier de nieuwe manual: http://gopro.com/wp-content/uploads/201 ... 009031.pdf
One Button Mode
Live Feed Out
r1 WVGA 50fps
r2 1280×720 25fps
r3 1280×720 50fps
r4 1280×960 25fps
r5 1920×1080 25fps
Re: GoPro HD Hero Firmware Update v02.05.11
Met de introductie van de nieuwe LCD BacPac;
http://gopro.com/hd-hero-accessories/lcd-bacpac/
Is er dus ook "nieuwe" firmware noodzakelijk;
http://gopro.com/support/hd-hero-firmware-update/
Echter, hier wordt nu weer gesproken over versie 01.01.46?
Marruk8865
Die wil ik wel hebben. Al in NL verkrijgbaar?
Ik zit nog te twijfelen, want dan gooi ik de Contour HD er wel uit, denk ik.
Nu alleen nog bedenken of zo’n GoPro wel handig is op de helm cq. wáár op de helm. :shock: :lol:
Aangezien ik net "vandaag" de aankondiging van deze LCD BacPac kreeg, denk ik dat deze nog niet in NL verkrijgbaar is.
Maar je kan via GoPro's website gewoon bestellen, heb ik al eerder gedaan voor delen die in NL niet verkrijgbaar waren.
Marruk8865
Mijn mening is dat de GoProHD echt niet te gebruiken is op de helm. Alhoewel hij er wel voor gemaakt is en op die manier gebruikt wordt lijkt het mij helemaal niets. Ik probeer het niet eens! Het blijft een groot ding.
Zoals je al zei levert de verkoop denk ik te weinig op en hou ik hem liever voor "erbij".
Ik wacht nog wel even met bestellen. Mocht jij hem wel een keer gaan bestellen hoor ik het wel. Dan kunnen we dat samen doen. Aan de andere kant vind ik het niet echt een must. Zelfs zonder de laser van de ContourHD is de GoProHD makkelijk uit te lijnen vind ik. Ik heb nog geen gemiste shots gehad;)
Ben het zondermeer met je eens dat de GoPro HD ongeschikt is voor op de helm, het mist de vormgeving van een "bulletcamera" zoals de ContourHD.
Montage bovenop de helm is te doen, maar wel een beetje "raar" met zo'n toren op je helm.
En eigenlijk geen porum, als ik eerlijk (tegen mijzelf) ben.
Aan de zijkant van de helm gaat ook wel lukken, maar ook daar is de GoPro geen gezicht.
Wat betreft de LCD BacPac, GoPro's website geeft momenteel aan dat er wat langere levertijden zijn ivm grote vraag.
Het loopt dus hard, heel hard. Want dat stond vanmiddag nog niet op hun site.
Laten we de rest van de aanschaf-discussie via PB doen.
PS: Volgens mij heb ik de vorige keer geen invoerrechten hoeven te betalen ivm economische waarde of zo iets.
jeroen12
Ik gebruik een oude helm (die ik extra meeneem) om de GoPro op te zetten. Het is idd geen gezicht, maar je kan er hele leuk opnames mee maken.
[media]9uWGvrRjVtg[/media]
Jammer dat je geen HD-versie hebt, dan is het helemaal top lijkt mij.
Maar, ik zag dat Contour (voorheen VholdR genaamd :roll: ) weer een aantal nieuwe mounts heeft uitgebracht.
Ik ga nog een poging wagen of ik de Contour goed ingesteld krijg qua belichting, exposure, etc, want anders ga ik serieus met de GoPro op de helm aan de slag.
Goed, niet gelukt dus met de vHoldR dus gaan we vrolijk verder met de GoPro HD, net zo gemakkelijk.
Ondertussen die v 01.01.46 in 1 van de GoPro HD's geladen, en beste Pierre, wat is er nieuw?
Nou, beste forum vrienden, 2 zaken zijn aangepast;
De "P" mode (zie je handleiding :lol:) oftewel de foto-maken elke x-seconden, was P2, P5, P10, P30 en P60.
Dus elke 2, 5, 10, 30 of 60 seconden automatisch een foto maken.
Nu is er ook nog P1 bij gekomen, dus elke seconde (!) een foto maken.
Als je die dan weer snel genoeg achter elkaar afbeeld, is het net een film! :lol: (geintje!)
En daarnaast natuurlijk "LCO" oftewel de optionele (_005) LCD BacPac aan of uit.
Kortom, ook al "klopt" die versie-nummering niet, de nieuwe firmware werkt.
Marruk8865
Dus als ik het goed begrijp is de versie waar jij nu over spreekt weer een versie later dan waarmee ik deze post startte? Heb ff de nummering niet bij de hand
Ja, v01.01.46 is blijkbaar nieuwer dan de v 02.05.11 waarmee je dit draadje begonnen bent.
Rare Chinezen die Amerikanen.
Ik zal anders GoPro Support ff een email sturen en navraag doen en hun reactie hier (uiteraard) vermelden.
PS: nog een paar tips;
Als je de firmware gaat updaten, vóór die tijd de camera even via het menu op R1 zetten.
Als de firmware goed geüpdate is, zal de camera de default R4 aangeven.
Als je, net zoals ik, onderhand een hele verzameling schroeven, houders e.d. hebt, zal je bemerken dat de schroef voor onder de camerabehuizing iets langer is dan de overige "reguliere" schroeven.
Om het jezelf wat gemakkelijk(er) te maken met graaien in de doos van mounts als je de camera wilt gaan monteren, alle (langere) cameraschroeven aan de rand gewoon met TipEx markeren bij de ring waar je duim en vinger in de buurt zitten.
Dan weet je welke de cameraschroeven zijn en welke de normale schroeven.
De normale schroeven zijn namelijk net ff te kort om als cameraschroef te gebruiken.
Als je toch al met TipEx bezig bent; :lol:
Doe ook een heel klein dotje op de bovenste rand van je SD-memory card. (dat gedeelte wat je net nog kan zien als de memory card in de camera zit)
De memory card heeft in dat gedeelte in het midden een kleine inkeping zitten, dus daar kan je (voorzichtig!) een klein druppeltje TipEx op doen.
Doe dit wel als de memory card *niet* in de camera zit, voor het geval dat je knoeit of zo. :roll:
Even laten drogen, terug plaatsen in de camera, en dan zie je door de waterdichte behuizing heen dat je een memory card in de camera geplaatst hebt.
(voorkomt oops-momenten)
Eventueel 1 dotje voor de 16Gb card en 2 dotjes voor de 32Gb card, dan weet je ook welke je erin hebt zitten, zonder dat je de GoPro uit zijn behuizing moet halen.
De vraag over de "version-confusion" is gesteld via GoPro's website, en ik kreeg (heel netjes!) een bevestiging per email met een case-ID.
Ik hou jullie op de hoogte en in ieder geval tot binnenkort op YouTube!
Helaas kreeg ik (mij althans bekende) reactie; don't deny nor confirm, don't give the customer rebuttal;
En dat je de firmware opnieuw moet laden als je de LCD BacPac de 1e keer monteert.
Blijkbaar wordt een deel van de firmware ook in de LCD BacPac geladen?
Anyhoe, ik heb mijn best gedaan, en zo heel boeiend is het nu allemaal ook weer niet.
Deze firmware "1.01.46" is dus inderdaad de nieuwste, maar de vraag hoe dat dan zat/zit met v02.05.11 wordt niet op ingegaan.The new firmware which is 1.01.46 is the new and latest firmware you need if you have your LCD screens or not.
Once you get your new BacPacs you also need to reinstall the new firmware.
En toch kon ik het niet loslaten, aangezien ik mixed-signals van GoPro Support kreeg.
(en ik ben een beetje eigenwijs en volhardend)
Wellicht dat ze in Bagalore zitten of zo?
Anyhoe, toch redelijk snel wederom een reactie op mijn vervolg-vraag gekregen, maar helaas de "versie-nummering discussie" wordt volledig ontlopen, ignore-and-deny, zoals ik eerder schreef.
Dus géén antwoord op de vraag over de versie-nummering waarmee dit draadje ooit begonnen is.
Ondanks mijn herhaaldelijke pogingen op een vriendelijke manier die vraag beantwoord te krijgen.
Wel antwoord op hun voorgaande reactie;
Als je eenmaal die v01.01.46 geïnstalleerd hebt op de GoPro HD Hero, ben je klaar voor de nieuwe LCD BacPac.
En mijn "online engeltje" verteld mij op dit moment dat het rond de 10e bij moet aankomen, dus nog een paar nachtjes...
:lol:
Apart, je manager vragen hoe het precies zit, dan heb je m.i. een probleem als support-persoon.Sorry for the confusion but I just asked my manager...
Once you have the brand new firmware installed and you receive your new LCD BacPac you will be good to go and do not need to reinstall it again.
- 25 Reacties
- 18072 Weergaves
- 12 Reacties
- 9689 Weergaves
Laatste bericht door strik
- 12387 Weergaves
- 14 Reacties
- 12209 Weergaves
- 8224 Weergaves
