GoPro HD Hero Firmware Update v02.05.11
Geplaatst: 30 jan 2011, 18:32
Ik weet niet of het oud nieuws is, maar voor de GoProHD gebruikers onder ons is er een firmware update beschikbaar.
Aangezien ik mijn camera al lange tijd niet gebruikt had kwam ik daar zojuist pas achter.
De nieuwe of gewijzigde functies:
One Button Mode
One Button Mode simplifies recording video and photos with your HD HERO. With One Button Mode, your camera will start recording video or photos automatically when you power the camera ‘ON’ and will only stop recording when you power the camera ‘OFF’. The shutter button is deactivated in One Button Mode. You can only turn the camera on and off, making it the perfect setting for loaning it to friends or newbies.
Upside Down Mode (UPd)
Now you can take videos and photos with the camera mounted upside down without having to rotate the files later. In UPd, all videos and photos will be saved to your SD card right-side up.
Live Feed Out
Display live feed SD or HD video and audio straight out of the camera to a TV, handheld viewer, or video transmitter. Allows viewing a live video signal during preview, recording, and playback of saved files.
Live Feed On-Screen Display
Display battery life, camera mode, and recording status icons on your live feed video signal with ‘On Screen Display’ turned on, or turn it off to transmit only the video without any status icons.
PAL 25/50 fps Support
If you live in a PAL region (most regions outside of North America) you can now record in the PAL broadcast standard of 25 / 50 fps in the following resolutions:
r1 WVGA 50fps
r2 1280×720 25fps
r3 1280×720 50fps
r4 1280×960 25fps
r5 1920×1080 25fps
Hier de update-instructies: http://gopro.com/wp-content/uploads/201 ... ctions.pdf
Hier de pagina om de update te downloaden: http://gopro.com/support/hd-hero-firmware-update (onderop na invullen naam en email)
En hier de nieuwe manual: http://gopro.com/wp-content/uploads/201 ... 009031.pdf
One Button Mode
Live Feed Out
r1 WVGA 50fps
r2 1280×720 25fps
r3 1280×720 50fps
r4 1280×960 25fps
r5 1920×1080 25fps
