Update 3.0 Schuberth SRC beschikbaar
- wil51
- Type: R850RT
Er is een update voor de Schuberth SRC.
What’s new in the SRC-System™ v3.0
Click-To-Link™
The Click-To-Link™ feature is a unique solution, developed by Cardo and available only to communication systems that are compatible with Cardo’s line of motorcycle communication systems. Click-To-Link™ allows bikers to initiate spontaneous intercom calls to random SRC-System™ users who are within range, without the need to perform advance pairing. Users can always activate or deactivate this feature and also reject incoming requests for such random connections.
Volume Per Mode
The Volume Per Mode feature causes the SRC-System™ to memorize the most recently stored volume setting for each audio source (A2DP stereo, mobile phone, GPS, FM radio), so that whenever a user switches between modes, the SRC-System™ will automatically transmit sound at the previously set volume level.
Stand Alone A2DP
A dedicated audio channel was added to accommodate A2DP-enabled music devices (such as the iPod Touch 2G/3G/4G). This provides the SRC-System™ with parallel connectivity to an MP3 device and a mobile phone, so that users can seamlessly switch from one to the other.
New convenient and simple Voice Configuration Menu
The new Voice Configuration Menu lets users easily change SRC-System™ settings and customize their unit without the need for a computer. User can now configure the following settings via the Menu:
Language
Enable/Disable Click to Link
Enable/Disable VOX
Enable/Disable RDS
Enable/Disable Spoken Status Announcements
Bug Fixes
Enhanced performance with TomTom Rider/Urban Rider GPS: GPS instruction audio connection is instantaneous
Solved bug in Intercom mode that sometimes caused the first syllable of speech not to be heard after a period of silence
Solved occasional distortion noise on an Intercom call that remained open for an extended period of time (~1hr+)
Secured seamless transition to A2DP playback after an Intercom call when using an iPhone™
Click-To-Link™
Volume Per Mode
Stand Alone A2DP
Language
Enable/Disable VOX
Enable/Disable RDS
Bug Fixes
Re: Update 3.0 Schuberth SRC beschikbaar
Bedankt!
Update gedaan, ging perfect. :-)
De meest recente handleiding is te downloaden via de navolgende link;
http://www.schuberth.com/fileadmin/down ... ch2011.pdf
PS:
Hoewel ik mij ingeschreven had om voor dergelijke updates een email te krijgen, heb ik vooralsnog nimmer een email gehad van Herrn. Schuberth hierover.
PS:
- wil51
- Type: R850RT
Managers van Schuberth en Garmin hebben misschien dezelfde opleiding hoe je met klanten omgaat. :lol:dutchmidiman schreef: Hoewel ik mij ingeschreven had om voor dergelijke updates een email te krijgen, heb ik vooralsnog nimmer een email gehad van Herrn. Schuberth hierover.
Maar dankzij het forum Waypoint was ik weer snel op de hoogte van de update. (ik heb geen aandelen bij Waypoint)
Ik ben benieuwd of dat Click-To-Link werkt. Bluetooth verbinding zonder te hoeven pairen met andere mensen die ook dit systeem ook gebruiken.
- HenkvanR
idem,dutchmidiman schreef:Hoewel ik mij ingeschreven had om voor dergelijke updates een email te krijgen, heb ik vooralsnog nimmer een email gehad van Herrn. Schuberth hierover.
heeft weinig nut zo om je in te schrijven, ik heb ook nog nooit wat gehoord van Schubert.
HenkvanR
Sterker nog; toentertijd (maart 2010 in mijn geval) moest je een account aanmaken om zogenoemd een software-update te kunnen ontvangen.HenkvanR schreef:idem, heeft weinig nut zo om je in te schrijven, ik heb ook nog nooit wat gehoord van Schubert.
Na het registreren kreeg ik de melding dat er geen update beschikbaar was.
Staaltje van marketingprietpraat, denk ik zo langzamerhand.
Maar toen (ook) ingeschreven voor de "valschade verzekering" (Schuberth Mobility Program) tbv 1/3 van de prijs als er binnen 3 jaar wat gebeurt met de helm.
Ach, dat was (ook) "gratis", en daar heb ik geen probleem mee.
Niet zo heel boeiend allemaal, er zijn vele
Ben meer verbaasd dat Schuberth vooralsnog heel weinig op dat gebied doet blijkbaar, toch een stukje service en klantenbinding, denk ik zo.
- wil51
- Type: R850RT
Updaten ging niet makkelijk. Kreeg aan eind melding "systeem error device niet aangesloten". Maar nieuwe software stond er wel op. Voor de veiligheid de oude software 2.20 weer geinstalleerd. Dat ging zonder foutmelding. Weer een poging om 3.0 te installeren. Toch weer de foutmelding aan het eind. Maar het lijkt er op dat 3.0 toch goed geinstalleerd is.
Ik heb tenminste de nieuwe functie click and link nu beschikbaar. Op de Zumo de koppeling verwijderd en opnieuw de helm gekoppeld. Op de Zumo staat nu SRC 3.0. Dat klopt dus.
Maar als ik eerst de Zumo aanzet en vervolgens de helm. Krijg ik eerst de stem die "gps" zegt, dan een tijdje niks en dan weer de stem met "gps aangesloten". Dat was niet zo, ik kreeg alleen de stem met" gps aangesloten" te horen. Zijn er meer gebruikers die hetzelfde horen?
Of had ik ook de helm naar de fabrieksinstelling moeten terugzetten voor het opnieuw pairen?
Vanmiddag even rijden of het probleem met soms wegvallen eerste woord bij de navigatie verholpen is.
Ik vind trouwens de software om de update en instellingen te veranderen niet erg goed. Staat de helm ingeschakeld komt toch de melding dat ik de helm moet inschakelen. Je moet eerst de software starten, wachten op de melding om de helm in te schakelen en dan kan je pas verder. Dan komt er weer een melding dat de helm uitgeschakeld moet worden, anders kan je weer niet updaten. Erg gebruikers onvriendelijk. En het kan ook niet op een Mac. Dat is ook al een groot minpunt. :lol:
Moet ik speciaal windows op mijn Mac installeren voor dit soort grappen. Nu maar even de laptop van mijn zoon geleend.
Ik heb de update ook gedaan maar op een "native" Windhoos-machine.
Ik heb dergelijke foutmelding niet gehad, het ging als de spreekwoordelijke brandweer.
Wel is het inderdaad zo dat het (herhaaldelijk) krijgen van een melding dat je de SRC moet aanzetten normaal is;
Om de software in de SRC te kunnen programmeren en te kunnen overschrijven, moet de SRC in een soort download-mode komen te staan.
En daarbij/voor plaatst het programma waarschijnlijk bepaalde software (loaders) op de SRC, waarbij je, denk ik althans, herhaaldelijk wordt gevraagd de SRC aan te zetten (terwijl je dacht dat deze al aan stond).
Maar als je goed op de ledjes let, zie dat er inderdaad bepaalde "standen of modi" gebruikt worden van de SRC tijdens dit programmeer-proces.
Ik weet niet welke Windows je gebruikt, maar bij Windows 7 moet je de administrator-rechten gebruiken bij het Schuberth update-programma.
En ik krijg netjes de melding "GPS Connected", geen pauzes of onderbrekingen, vooralsnog.
- wil51
- Type: R850RT
Proefritje gemaakt. Navigatiestem niet te horen. Ook niet op maximaal volume. MP3 wel goed. Truus blijft stotteren bij de melding gps verbonden. Oude versie 2.20 weer terug gezet en alles werkt weer zoals het moet.
Welk Zumo navigatie-apparaat-ding gebruik je? (model)
En is die voorzien van de laatste software, indien van toepassing?
Danwel welke software-versie draait daar op?
- wil51
- Type: R850RT
Ik gebruik de Zumo 660 met software versie 4.20.
Op forum Waypoint zijn ook al reacties met dezelfde problemen.
update nogmaals uitgevoerd. Blijkt dat voor navigatie het volume op nul is gezet door de update.
Nu kon ik ineens wel het volume navigatie verhogen. In plaats van gps verbonden, hoor ik nu gps, dan tijdje niks en dan gps aangesloten. Vreemd, maar het werkt nu.
Apart, ik heb vooralsnog geen problemen geconstateerd, navigatie was prima hoorbaar de gehele rit.wil51 schreef:Op forum Waypoint zijn ook al reacties met dezelfde problemen.
Welke update refereer je naar?wil51 schreef:Blijkt dat voor navigatie het volume op nul is gezet door de update.
De update van de SRC of van de Zumo 660?
Ik denk dat je twee meldingen gelijktijdig krijgt, of vlak achter elkaar.wil51 schreef:Nu kon ik ineens wel het volume navigatie verhogen. In plaats van gps verbonden, hoor ik nu gps, dan tijdje niks en dan gps aangesloten. Vreemd, maar het werkt nu.
1 van de SRC dat de bluetooth verbonden is met de Zumo en 1 van de Zumo zelf. (wellicht)
Of beide boodschappen van de SRC, die vlak achter elkaar komen en zich blijkbaar een beetje in verslikt.
Daarom heb ik de SRC in het Engels staan, dan weet ik welke melding van welk apparaat komt.
NL is Zumo, Engels is SRC.
- wil51
- Type: R850RT
De update van de SRC zet het volume op de SRC op nul.
Het krijgen van een foutmelding aan eind van update wordt nu ook meer gemeld. Na de derde maal update uitvoeren was het pas zonder foutmelding. Ik deed de update met Windows 7 als administrator.
Dan zal ik heel veel mazzel gehad hebben, want ik heb al die problemen niet gehad noch ondervonden.
Update/correctie;
Kreeg vandaag een email van Herrn. Schuberth dat de SRC update v3.0 update beschikbaar gekomen is.
Waarschijnlijk enige vertraging door het feit dat de email in het "Nederlands" was opgesteld.
---- knip, scheur ------
De nieuwe SRC-Systeem™ v3.0 firmware is aangekomen!
Zeer geachte dames en heren, beste Schuberth klanten,
De nieuwe firmware v3.0 voor uw SRC systeem is aangekomen.
De nieuwe firmware biedt u interessante nieuwe functies en helpt u bij het optimaliseren van bestaande functies:
- klik-om-te-linken™
- volume per modus
- draadloos A2DP
- spraakgestuurd configuratiemenu
- fout-oplossingen
Hier komt u direct in het gebied om te downloaden;
http://www.schuberth.com/en/produkte/se ... nload.html
Wij wensen u met uw SRC-Systeem™ en uw Schuberth flip-up helm verder veel plezier en een voortdurend rijplezier zonder ongelukken.
Hartelijke groeten uit Magdeburg
Uw Schuberth Service-Team
Klik-om-te-linken™
Met klik-om-te-linken™ kunt u intercom-gesprekken met andere SRC-Systeem™-gebruikers in de omgeving spontaan opnemen, zonder dat een voorafgaande koppeling (pairing) van de apparaten vereist is.
De gebruikers kunnen deze functie op elk moment activeren of deactiveren en inkomende aanvragen tot verbinding afwijzen.
Volume per modus
De functie volume per modus geeft het SRC-Systeem™ opdracht, de laatst opgeslagen instelling van geluidssterkte voor elke audiobron (A2DP stereo, mobiele telefoon, GPS, FM-radio) op te slaan.
Tijdens het omschakelen tussen de modi wordt het geluid bijgevolg steeds in de van te voren ingestelde geluidssterkte overgebracht.
Draadlloos A2DP
Het SRC-Systeem™ werd met een speciaal audiokanaal voor draadloze muziekontvangst met apparaten met A2DP-ondersteuning (zoals b.v. de iPod Touch 2G/3G/4G) uitgebreid.
Dankzij deze functie biedt het parallelle aansluitmogelijkheden voor MP3-speler en mobiele telefoon, zodat twee verschillende apparaten afwisselend gebruikt kunnen worden.
Nieuw spraakgestuurd configuratiemenu voor eenvoudige en comfortabele bediening:
Dankzij het nieuwe spraakgestuurd configuratiemenu kunnen gebruikers de SRC-Systeem™-instellingen simpelweg veranderen en hun apparaat zonder gebruik van een computer aan hun behoeften aanpassen.
Volgende instellingen kunnen via het menu geconfigureerd worden:
- taal
- klik-om-te-linken™ activeren/deactiveren
- VOX activeren/deactiveren
- RDS activeren/deactiveren
- gesproken statusmeldingen activeren/deactiveren
Fout oplossingen:
- Verbeterde prestatie in het navigatiesysteem TomTom Rider/Urban Rider: de audioverbinding voor de overdracht van GPS-instructies wordt direct tot stand gebracht.
- Opheffen van een fout in de intercom-modus, op grond waarvan de eerste lettergreep na een pauze in het spreken tot nu toe niet hoorbaar was.
- Opheffen van een incidentele vervorming bij intercom-gesprekken, die gedurende een langere tijd (~1 Std.+) in stand gehouden werden.
- Veilige naadloze overgang naar A2DP-weergave na een intercom-gesprek bij gebruik van een iPhones™
----- plak, nietje, ga rijden en genieten -----
- volume per modus
- draadloos A2DP
- fout-oplossingen
Klik-om-te-linken™
Volume per modus
Draadlloos A2DP
- taal
Fout oplossingen:
Nieuw bericht Schuberth SRC firmware update - beschikbaar!
door Inspector Gadget » » in Over: Communicatie - 10 Reacties
- 4252 Weergaves
- 2271 Weergaves
Nieuw bericht Update tbv GS-911 Diagnostic tool beschikbaar
door Inspector Gadget » » in Elektrische Systemen - 0 Reacties
- 1399 Weergaves
Nieuw bericht Garmin kaart-update beschikbaar: 2012.10
door Inspector Gadget » » in Over: GPS en navigatie - 9 Reacties
- 2923 Weergaves
Laatste bericht door wil51
