---- knip ----
Fixed Problems:
VOX may not always work while listening to FM.
When switching between IC to A2DP, there is a volume jump.
A2DP Volume is too high.
It occasionally happens that after intercom calls are overridden, FM comes back instead of the intercom call.
When Intercom call is ongoing while being connected to GPS and the GPS is turned off, the intercom call doesn’t
always come back automatically
It occasionally happens that the call-waiting beep will not be heard.
While listening to wired MP3, the status lights appear wrongly (flashes once instead of twice every 3 seconds).
FM audio is heard for 2-3 seconds after the HS is turned off while listening to the Radio.
When turning off headset you only receive one beep, instead of the Descending Tone (High-Low).
When paired with Zumo 660i, the A2DP profile is disabled.
On some headsets, weak static noise is heard for 1-2 minutes after powering on the headset.
During this time, the headset still functions well and allows receiving of call by VOX.
During 3-Way calls, if one among the participants gets disconnected, he has occasionally difficulties to reconnect.
Headset may stop responding when user listening to FM radio and RDS features is set to ON (default is OFF).
---- knip ----
http://www.schuberth.com/en/products/se ... nload.html
