Update 3.0 Schuberth SRC beschikbaar
Geplaatst: 17 mei 2011, 07:53
Er is een update voor de Schuberth SRC.
What’s new in the SRC-System™ v3.0
Click-To-Link™
The Click-To-Link™ feature is a unique solution, developed by Cardo and available only to communication systems that are compatible with Cardo’s line of motorcycle communication systems. Click-To-Link™ allows bikers to initiate spontaneous intercom calls to random SRC-System™ users who are within range, without the need to perform advance pairing. Users can always activate or deactivate this feature and also reject incoming requests for such random connections.
Volume Per Mode
The Volume Per Mode feature causes the SRC-System™ to memorize the most recently stored volume setting for each audio source (A2DP stereo, mobile phone, GPS, FM radio), so that whenever a user switches between modes, the SRC-System™ will automatically transmit sound at the previously set volume level.
Stand Alone A2DP
A dedicated audio channel was added to accommodate A2DP-enabled music devices (such as the iPod Touch 2G/3G/4G). This provides the SRC-System™ with parallel connectivity to an MP3 device and a mobile phone, so that users can seamlessly switch from one to the other.
New convenient and simple Voice Configuration Menu
The new Voice Configuration Menu lets users easily change SRC-System™ settings and customize their unit without the need for a computer. User can now configure the following settings via the Menu:
Language
Enable/Disable Click to Link
Enable/Disable VOX
Enable/Disable RDS
Enable/Disable Spoken Status Announcements
Bug Fixes
Enhanced performance with TomTom Rider/Urban Rider GPS: GPS instruction audio connection is instantaneous
Solved bug in Intercom mode that sometimes caused the first syllable of speech not to be heard after a period of silence
Solved occasional distortion noise on an Intercom call that remained open for an extended period of time (~1hr+)
Secured seamless transition to A2DP playback after an Intercom call when using an iPhone™
Click-To-Link™
Volume Per Mode
Stand Alone A2DP
Language
Enable/Disable VOX
Enable/Disable RDS
Bug Fixes
