zumo 660 firmware 3.90 beschikbaar
Geplaatst: 14 jul 2010, 10:19
gisteren update uitgevoerd en firmware 3.90 is available.
Alles werk nog naar behoren. Het schijnt dat 3.80 niet goed was (zie gps forum waypoint). Daarom zal 3.90 ook wel zo snel gekomen zijn!!
Changes made from version 3.80 to 3.90:
Corrected spontaneous shutdowns that could occur when satellite reception is temporarily lost.
Corrected intermittent issue with music not resuming after a navigation prompt when paired to A2DP headphones.
Corrected some languages not showing up on the unit.
Corrected problems with the turn arrow in More Map View.
Corrected a shutdown that could occur while reviewing off road tracks.
Corrected an issue that could cause the unit to not shut off when connected to external power.
Corrected importing only the first 650 points of some off road tracks.
Corrected incorrect color on Netherlands Topographic Map.
Corrected an issue calling some POIs.
Corrected a possible shutdown when searching for cities.
Corrected unit freezing when reviewing some POIs.
