Nieuw: RapidBike EVO
Geplaatst: 09 jan 2010, 12:10
Al zoekend naar ervaringen met RapidBike 1,2,3 kwam ik terecht op de site van Dimsport Technology, de ontwikkelaar & fabrikant van RB. Sinds 1 december hebben ze RB-EVO een nieuw product, dat neerkomt op een combi van RB en RB-O2 (soort Recyclizer). Mijn PowerFRK gaat daarom terug en er komt in maart een RB-EVO!
Kosten bij Fredriks in Goes incl inbouwen en testen € 550,- (is nu op voorraad).
Ik ben erg benieuwd wat dit inhoudt:
http://web.dimsport.com/rapidbike/rapidbike.php#tab2
Self-correction of maps through steps and timer range
01-12-2009
NEW RAPIDBIKE EVO!
Rapid Bike EVO - add-on module to set and control carburation of bikes.
"total injection control" is the name of the RB tecnology evolution: setting and control of fuel injection system with a single module, the RB EVO. It works simultaneously on the injection values and on the signal of the Oxigen sensor, so maintaining performance over time.
Technical Features:
Management of up to 8 injectors with the possibility to reach up to 150% more and 100% less in the injection time
Modulation of Oxigen-sensor signal following the injection map (RB-O2 and Rapid Bike in one module)
Management of electronic shift with possibility to modify the Cut-off time according to RPM and gear position
Advanced change of maps following features that can range from the gear engaged up to the position of the injector
Change of maps while riding by using the optional switch on handlebar
Maps that can be customized with 320 points gain and RPM figures with steps of 50 RPM
Managment of the signal coming from gear position in order to remove speed limiter
Advanced features for map managment following the position of gear change
CAN-bus line for interaction with peripheral devices and reading of engine working parameters
Waterproof wires with OEM connectors
Compatible with all accessories, Dynolink and Tuning Bike included
Case made of aluminum alloy-castings
12v dc power supply and USB PC-connection
